Drive clutch puller
Old Sep 24, 2010 | 07:15 PM
crcmech's Avatar
Default Drive clutch puller
Anybody know the OEM number for the drive clutch remover for a 2000 sportsman 500?I need it so I can get the correct one,thanx
Old Sep 25, 2010 | 05:10 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you could just make your own out of a 3/4" fine thread long bolt. if not i would buy an aftermarket puller as it would be alot cheaper then oem. imo
Old Sep 25, 2010 | 11:46 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
+1 Go to your local hardware and find a long bolt or pick up a 8-12" piece of 3/4 fine thread rod and a couple bolts at one end to put a wrench on.
Old Sep 26, 2010 | 07:35 AM
zzoomz's Avatar
will this work on a '04 600 as well?
Old Sep 26, 2010 | 09:25 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. it should be the same.
Old Sep 26, 2010 | 10:51 AM
zzoomz's Avatar
Ok thanks, so I just thread it in to the clutch and the clutch should just pop off?
Old Sep 26, 2010 | 11:08 AM
TLC's Avatar
TLC
Here is the home made one at work.
YouTube - Changeing belt POLARIS ATV
Old Sep 27, 2010 | 05:39 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
using an imapck is the easiest. sometimes you have to put pressure on it then hit it w/ a hammer if it's been along time.
Old Sep 28, 2010 | 08:10 PM
zzoomz's Avatar
ok I am going to try and get it off tomorrow
Old Sep 29, 2010 | 02:52 AM
marc2000gt's Avatar
I have not tried it myself yet, but I have read to fill the hole that the puller goes in with grease. That is supposed to help push the clutch off when the grease is compressed. That way hopefully you don't have to use a hammer. It may work but I don't like the idea of hammering on anything that has bearings.
Cummins Driver
Sep 11, 2019 01:22 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
kdg723
Jul 25, 2015 01:20 PM
ghost civic
Jul 15, 2015 10:48 PM
clsharky
Jul 13, 2015 02:07 PM
