Is this a good winch for my 850 ?
Old Sep 24, 2010 | 09:44 PM
zeus-fl's Avatar
Default Is this a good winch for my 850 ?
I am shoping around a winch for my 850.
What do you think about this one. 4000LB ATV Winch Polaris Sportsman 2009-10 550 & 850 XP: eBay Motors (item 280527007239 end time Sep-25-10 16:26:33 PDT)
Old Sep 24, 2010 | 10:17 PM
zeus-fl's Avatar
Well. Finally i take this one. 3000LB ATV Winch Polaris Sportsman 2009-10 550 & 850 XP: eBay Motors (item 270578259044 end time Oct-09-10 15:56:50 PDT)=
Old Sep 25, 2010 | 07:34 AM
dodgefreak8's Avatar
the viper would be a better choice
Old Sep 25, 2010 | 01:49 PM
zeus-fl's Avatar
i take the venom :-(
Old Sep 28, 2010 | 10:34 AM
Graybeard14's Avatar
I bought a venom last year for my grizzly with snow plow. had a gear box issue, but it was under warentee. they were very easy to work with and have had no problem with it after it was fixed/replaced.
Bought an xtreme this time to try the rope, was very disapointed when it came with cable on spool and rope in bag (not like in pic). Both units were not easy to mount, had to resize some holes to make fit. mounted it on a 2010 800 sportsman. The relay would not work with factory installed wiring, with out modifiying the relay (grinding on the plastic). could not find info on how to wire with factory wires and had not run across this forum yet. Figured it out and works fine, will have to see how it performs this winter.
Good Luck
Old Sep 28, 2010 | 12:19 PM
zeus-fl's Avatar
Well. Look like will be non-easy work to do. Thank you a lot for your info. I will check if have any recall.
Old Sep 28, 2010 | 12:45 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
WARN is the way to go.
Old Sep 28, 2010 | 05:34 PM
XPQuadMan's Avatar
I purchased of these over a year ago. Great winch for the money. I use it all the time for plowing. With the money I saved vs getting a Warn I was able to get Ricochet a arm guards. VIPER ELITE 3500LB Winch
Old Sep 28, 2010 | 10:32 PM
I have to agree with XP, no more then I use it, it is the best walue for the dollar. If I made my living with the wench, I might have to re-think it. But when you save the money, it usually cost you some where else. The over all fit of the parts did cost me time in putting it all together, but that is the fun part, making it all work.
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
