Demand drive fill plug stripped (hex head)
I have been through this before but not on my PoPo,I soaked it with PB Blaster and used a tad larger star "torx bit" than the actual rounded allen plug and lightly tapped it in with a small ball ping hammer until it bottomed and used a ratchet to remove it,most get resessed down into the hole when tightned and impossible to get a chisil to.That worked for me?
You don't happen to remember the p/n do you? I don't have access to air tools so I was going to ride it from the house (no truck or trailer) to a local shop (not the dealer) and have them take it out and put the new one in, I don't really have a way to take the old one to napa to match it up.
On the bright side, I drained my tranny and the oil was fine, thought it had water in it because if was running out the fill plug.. guess I must have overfilled it last time.
#16
I'm thinking I use a 3/16" allen on my 500,not metric but I'm sure they have changed over the years.I have a set of metric and std impact hardened torx bits "Harfor Freight Specials" some I've tapered at the tip with a file to make it easy to enter stripped out allen bolts/plugs.I found the cheap non heat treated type will break off easy
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
