Check this guys video one a 500H.O oil change!
#21
I am a maintenance novice and am just curious if this is something I can pull off on my own? I watched the good video on the thread and it doesn't seem to difficult. I called to see how much it would cost me (first oil change/"Maintenance" is 350-400 dollars) to get it done, and I would rather not pay that. Also, where is the best place to get the oil/filter from. Thanks in Advance
#22
Hate to tell you "Spdecat" but the 500 H.Os (Carb) still have a ECM/ECU since 2004.5.
9000miles in just 3 years! We only have $7500 on our 1997 SP500
Part#1 OEM motorcycle and ATV parts from Honda, Yamaha & Polaris – Cycle Parts Warehouse
Back to topic, All the Fluids ,filters are easy to change on the 500. Even if my dealer offered to do it for free labor,it would be a hassle just to transport drop the ATV off and pick it back up again.
#24
You may want to read through this to save money. Make a list of common numbers we need
The fuji 500 motor never changed so do not worry about the year of the ATVs.
I use a Fram CPH6607 but there are many,many more.
#25
$350 to $400 for a service. Your dealer is a criminal SOB. About 30 to 40 dollars worth of fluids and a filter and at the most one hour labor.
I wish I could make money like that but if I had to do it so dishonestly I will not do it.
#27
It's called a PDM don't scare me with those three letters ( ECM/ECU) . What ever it has I'm happy with it as it's ran and been problem free for 9000miles and I'v never seen a code
#29
They call the brain box my beast has a PDM or Power Distribution Module as per the Polaris shop manual that I have . Only time a ECM/ECU is mentioned is when there referring to the EFI models that I'm happy I don't have .
