Check this guys video one a 500H.O oil change!
Old Nov 20, 2010 | 12:01 PM
  #31
09 popo HO's Avatar
Just ran the numbers and it turns out my 500 uses the same oil filter as my Nissan Altima 3.5, too easy. No reason not to stock up on some filters next time they go on sale.
Next oil change is definitely going to be Mobil 1 and a wix filter. No more paying 35 bucks plus tax for an oil change kit from the dealer anymore. Should be able to do it for 25 without a sale.
Old Nov 21, 2010 | 12:53 PM
  #32
VegasF6's Avatar
Hi all, new member so pardon any stupid questions. I have a 2004 sportsman 600 carb. Does it also have a separate oil tank, and does everything in this video apply to mine? (2 separate drain plugs, oil screen, priming pump, etc.)
Old Nov 22, 2010 | 06:49 PM
  #33
NSchindler's Avatar
Im thinking Im going to attempt this on my 05 400. It looks similar to the video. Only question I have is how do you know for sure you "primed" the oil pump?
Old Nov 22, 2010 | 07:47 PM
  #34
Spdecat's Avatar
If you don't remove the screen you don't need to prime the oil pump .
Old Nov 22, 2010 | 08:08 PM
  #35
Overdrive's Avatar
You have ONE drain plug under the engine. It takes a 6mm Allen wrench.
It holds 2 quarts. No priming no screen to clean.
Old Nov 22, 2010 | 10:40 PM
  #36
kcaves's Avatar
the pdm is basically your regulator/ rectifier, and it distributes power to everything that needs power. and on a 600 you fill ur oil up through the dipstick tube, no tank to fill
Old Dec 14, 2010 | 07:12 PM
  #37
nation's Avatar
would this procedure be the same for a 99-02 scrambler 500? both mine need a fluid change. ive managed to use walmart for all my toys up to this point. i was going to grab a couple fram filters and 0w-40 oil.
Old Dec 14, 2010 | 08:16 PM
  #38
VegasF6's Avatar
Oh, I was expecting a notification of reply. Perhaps I missed it. Thanks Overdrive. It's done.
Question 2, where is the darn oil filler? I ended up filling it through the dipstick and it was quite a bear. Please tell me I am just stupid and missed the filler hole?
Old Dec 14, 2010 | 10:06 PM
  #39
brainpause's Avatar
Originally Posted by TLC
YouTube - Changing Oil On Polaris Sportsman 500 HO.mp4
3 quarts! Maybe more! and just fill the oil tank to the top. LOL
What a Doofenschmirtz.
Old Dec 15, 2010 | 05:40 AM
  #40
TLC's Avatar
TLC
500 Sportsmans and 500 Scrambler have the same motor,so you change the oil the same.
Dabears1983
Jun 16, 2015 12:17 PM
Trxoutlawz
Mar 2, 2001 09:33 AM
OLDSTER
Jan 9, 2001 10:13 PM
in2atvn
Sep 20, 2000 04:58 AM
JRM
Nov 19, 1999 01:41 PM
