Sanding out scratches?
Old Nov 15, 2010 | 11:38 PM
8fitty's Avatar
If the paint has clear coat you can color sand and buff it. Be very careful not to go through the clear. If you do you will not be able to buff it out. When you sand a metalic paint it will turn very dark and have uneven paterns.
I think if you take your time it should be fine.
Old Nov 17, 2010 | 06:43 PM
jampg's Avatar
Default go easy
Originally Posted by bentarrow
Lovmudd!! I hope you missed adding a 3rd 0 on the grit.
Yeah, but he did say they were DEEP.....
Old Nov 18, 2010 | 07:05 AM
lovmudd's Avatar
Jampg,
You are correct the scratches are deep, like about 36 grit, caused from road rash from a roll over. My main question was to ask if the colored green plastic could be sanded well below the surface and then buffed. It doesn't look like there is any paint or clear used on the plastic, rather the color is in the plastic, thus the question.
Old Dec 9, 2010 | 07:09 PM
rastegsr's Avatar
Default removing scratches can be done
Scratches can be removed with a propane torch, no really i didn,t believe it till i saw it done on U TUBE. Goggle ---plastic welding---and on utube u will see it done.I tried it and it really worked well. u just have to take is slow'
Old Dec 9, 2010 | 08:41 PM
  #15
brainpause's Avatar
http://www.youtube.com/watch?feature=youtube_gdata_player&v=oI0T9m47ja0
black_thunder
Sep 20, 2015 10:21 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
rawbdiggity
Sep 7, 2015 12:05 PM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
