SP500 HO idle problem
Old Nov 22, 2010 | 06:08 AM
mw500's Avatar
Turns out there was a small crack in the rubber carb boot as well. Should I turn the fuel/air screw back to 1 3/4 turns out where it originally was, or leave it at 2 1/2 out?
Old Nov 22, 2010 | 06:51 AM
kcaves's Avatar
just leave it at 2 1/2 out
Old Nov 22, 2010 | 11:54 AM
pwssr's Avatar
Originally Posted by bentarrow
You might try adjusting the throttle cable, after 6 years it might be stretched just enough to not idle when cold. Corrected the same type of problem on 1 of my 02 500s.
Sounds like there is a misunderstanding here! The throttle cable should not have anything to do with the idle level - if it does, then it is too tight. When the throttle is at "idle", the throttle lever on the carb must rest on a stop, typically the idle screw. The motor should idle at the proper RPM with the cable disconnected....
Old Nov 22, 2010 | 10:20 PM
kcaves's Avatar
no, polaris has a electric throttle control basically if ur throttle sticks open or too much free play in the cable, it will shut down the engine
Old Nov 24, 2010 | 12:55 PM
  #15
TLC's Avatar
TLC
Maybe this. Polaris ATV Thumb Throttle Maintenance Tips: Polaris ATV Maintenance & Repair Tips | eHow.com
Old Nov 24, 2010 | 07:03 PM
  #16
mw500's Avatar
I had to order a new exhaust gasket & carb boot, dealer didn't have either on hand. I'll report back next week with results. Thanks to all for the advice.
Old Nov 29, 2010 | 01:51 PM
  #17
mw500's Avatar
Well, that didn't help at all. The idle speed is still erratic, varies by 700-800 rpm. I noticed my oil smells like gas too. Any other suggestions? Thanks.
Old Nov 29, 2010 | 01:54 PM
  #18
Kerbbirds's Avatar
is ur oil level high as well, if thats the case than either ur float is stuck or ur needle and seat is bad in the carburetor
Old Nov 29, 2010 | 02:10 PM
  #19
mw500's Avatar
Yes the oil level is high.
Old Nov 29, 2010 | 02:24 PM
  #20
mw500's Avatar
Anyone know how to disconnect the throttle at the carb on an '04.5 500HO? It's not the slide type throttle I'm used to, the throttle is on the right side of the carburetor. thanks.
