SP500 HO idle problem
Old Nov 20, 2010 | 11:19 AM
mw500's Avatar
Default SP500 HO idle problem
2004 500HO won't idle after normal warm-up time, have to keep giving it throttle to keep it running. After riding for 5-10 minutes it will idle on its own, but rpm will vary from 900-1150 (normal idle is about 1250). Also seems to sputter out the exhaust (almost like subtle backfiring) when I let off the throttle quickly, otherwise it runs great except at idle. I thought it was water in the gas but that wasn't it. Plug & fuel filter have been changed, air filter is clean. Any other suggestions? I guess cleaning the carb would be next.
Old Nov 20, 2010 | 03:52 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
chances are if it starightens it self out some what after warming up then i would guess the carb wouldn't be dirty as the issues shouldn't go away just by warming it up.(imo) by any chance is thier any kind of exhaust or air leak of some kind causing the changes in the idle? just a thought.
Old Nov 20, 2010 | 05:31 PM
mw500's Avatar
I've checked for air leaks & the only thing I've found is some surface cracks on the rubber piece that the carb attaches to, but they don't look nearly deep enough to leak. Haven't looked at the exhaust, but that would make sense. I think it's one piece right back to the silencer so there's not too many places it could leak. Must be a gasket where the silencer meets the pipe though so maybe that's it. I'll give it a look. Thanks.
Old Nov 20, 2010 | 06:24 PM
Bowana's Avatar
Try spraying some carb cleaner on the carb boot when it is running. If it runs faster as a result, those cracks are all the way through and it is sucking air and time to change the boot. Might be a good time anyway for if it leans out too much the result is a scored piston.
Old Nov 20, 2010 | 08:14 PM
Kerbbirds's Avatar
Need to drill a hole in the brass cap that is covering the air-fuel screw, then screw a sheet metal screw in it and remove the brass cap so you can set the screw at 2.5turns out, Polaris put out a service bulliten on this some years back, I have done several and found the screw anywhere from 3 turns out to all the way shut. The brass cap and screw are on the bottom of carb
Old Nov 20, 2010 | 11:26 PM
bentarrow's Avatar
First Things First!
You might try adjusting the throttle cable, after 6 years it might be stretched just enough to not idle when cold. Corrected the same type of problem on 1 of my 02 500s.
Old Nov 21, 2010 | 07:10 AM
mw500's Avatar
Well I took the exhaust apart and one of the gaskets is very worn & shiny, looks like its been spinning around in there for quite some time. I'm hoping this is the problem, I'll pick up a new one tomorrow and see if that does the trick.
Old Nov 21, 2010 | 07:20 AM
Boss Man's Avatar
Whether that's the problem or not, I would do what a couple others have suggested. Make SURE your throttle cable slack is adjusted properly. Then, get that brass plug out of the carb so you can adjust the idle speed fuel/air flow mixture. The manufacturers have to set them lean to meet government regulations. If you are running gas with Ethanol in it, it will only run leaner... that's why you need to be able to adjust that mixture.
Old Nov 21, 2010 | 08:55 AM
mw500's Avatar
Throttle cable adjustment is good. Air-fuel screw was 1 3/4 turns out so I turned it to 2 1/2 out.
Old Nov 21, 2010 | 02:40 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
let us know what you find that fixes it.
