Trail Boss 330 off-idle stumble
You could change the primary spring. Can't remember now if it's Polaris pink or white that would be better for you.
Also, if you don't want to mess with that, you could change the sprockets. Needed a new set up (chain and both sprocket) on mine thanks to a nice big rock. Might want to check the chain for missing o-rings and the sprockets for wear.
#15
#16
#17
#19
#20
Thanks.....I'll give that a try. Do you happen to know of any instructions available to change and adjust springs? That's something I've never done before.
