XP 550 Engine Pro vs Con
Old Dec 9, 2010 | 03:16 PM
  #21
Ghost Rider 11's Avatar
Originally Posted by Millrod
Yep, build by Fuji.....quality seems to be on par with the venerable 500. The 550 engine is no where as smooth as the 850 but what do you expect from a big single? Engine durability seems to be good considering the many reports of high mileage users having no problems at all, on this forum and others.
One side effect of the lighter single is that the chassis front/back weight balance is significantly different than the 850....the front end feels lighter and tends to plunge through the suspension and roll much less under aggressive usage.
This isn't desirable or important to everyone but the 550 doesn't have "power up into a wheelie" capability like the 850 but leaning back and popping the throttle will lighten the front end enough to get over obstacles or let you pull it into a wheelie if you are so inclined.
Albeit not quite as fun as the 850, all things considered the 550 is a capable, comfortable, easy bike to ride with amazing chassis ergonomics, ride and handling, and a motor that won't to kill novice or careless riders.
The front end is light, but the front springs are way to soft and cause a lot of body roll in the front end. Ive had to adjust the front springs and that helps, but it would be a lot better if the front springs were about 25% stiffer than they are now.
Old Dec 9, 2010 | 10:52 PM
  #22
biz4two's Avatar
Thumbs up
Originally Posted by Ghost Rider 11
The Bighorns are installed on the stock rims, and they fit just fine.
Here is a couple of pictures
Also remember that Bighorns run bigger than stock tires, so a 26'' Bighorn measures almost 27''.
Now that is a TRICK XP 550! Nice ride...
OBTW: Are those fender extentions? Brand? How/where to purchase?
Thanks!
biz
Old Dec 9, 2010 | 11:51 PM
  #23
Thanks!
biz
Thanks
There Kolpin overfenders, i bought them on Amazon.com, they were the cheapest there at 134.00 dollars.
Old Dec 11, 2010 | 06:20 PM
  #24
Kerbbirds's Avatar
do those fenders go in thee factory holes? I like them if they do
Old Dec 11, 2010 | 06:45 PM
  #25
I believe you have to drill holes in the fenders to mount fender extensions, i had my dealer install them for me while they were mounting my new tires.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
