my four wheeler has no power
then chanaces are it's not the carb, but most likely the secondary buttons are worn out and making it seem like its starting in high gear w/ no pulling power. imo
it does rev up in neutral, but i dont think it is reving as high as it should.
when i ride it, it doesnt cut out, it only goes about half of full speed. i hope this makes some kind of sense.
#16
I am experiencing the same symptons with my Polaris '04 Sportsman 400. It started a couple of months age and has gotten worse. It will not idle unless it is up to operating temperature and has no power in high range. I checked the carb and jets only to find no obvious sediment or dirt. I installed new plug, fuel filter and no help. It runs fine in low range. BTW, I have been using this to plow lots of snow. It currently has 6800 plus miles on the engine and approx. 650 hours running time. Help! MTG
#17
first of all, thanks to all that replied. cleaned the carb. made a huge difference in the rpms. the engine reved up much higher than before, so much so, it started to back fire thru the carb. after some advise, checked the cam. guess what. the exhaust lobe is worn almost round. guess i need some new parts.
Thenson
Apr 10, 2018 06:22 PM
