Polaris Sportsman engine covered in oil
Old Dec 12, 2010 | 08:55 PM
brainpause's Avatar
My TB's exhaust valve cover was cracked and did similar things, but in a different area than what you are seeing. Mine are plastic; not sure about yours. If your intake valve cover is loose or cracked, maybe that's your issue.
Larry
Old Dec 12, 2010 | 10:08 PM
x2 bum's Avatar
I would clean it up then run it for a short time, then check to see where the oil is coming from. If you run it for a short time you should be able to read the oil spill pattern to see where the source is. my .02
neilbedwell
Nov 10, 2018 11:02 AM
gfl0224
Jun 27, 2015 06:52 PM
yellowpolaris
Jun 21, 2015 11:13 AM
Schneider
Jun 4, 2015 11:37 AM
May 27, 2015 11:15 AM
