rear axle nut removal
Old Dec 16, 2010 | 02:29 PM
drkilldrmz's Avatar
Default rear axle nut removal
2003 2wd trail boss 330. need to replace rear axle beaings. Got the tire, hub, snap ring, and seal off, now.. i cannot for the life of me remove the rear axle nut from this thing. Tried heat, Kroil, larg channel locks. No dice. I have a pipr wrench that fits pretty snu, and using a breaker bar and BFH i still cannot get it to budge. Any tricks here? Doesn't seem to be threaded reverse..And. If i cut it off, can i just use a nut of the same size with locktite, and ignore the snapring? Thanks in advance..
Old Dec 16, 2010 | 04:10 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it's most likely on w/ loctite. you sure it's not left handed threads? just a thought. maybe try it the other way to see if it moves any. just a guess w/ out seeing it.
Old Dec 16, 2010 | 05:39 PM
drkilldrmz's Avatar
I ran my nail on the threads to make sure..Where are you in maine? Im in Gray..
Old Dec 17, 2010 | 06:07 AM
ftwflh's Avatar
Easiest way is to use a Dremmil tool to cut the nut almost through in two spots and then split with a chissel.Replace the nut.I keep extras in my tool box
Old Dec 17, 2010 | 07:02 AM
drkilldrmz's Avatar
It's a good thought. Can't locate the nut locally though. Can a regular nut be used in place of the old one? Only problem would be the snap ring..Edit..FTW.. That mean that the threads are normal also correct?
Old Dec 17, 2010 | 05:54 PM
ftwflh's Avatar
you will need a factory nut.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Jul 28, 2015 01:58 PM
Bell21
Jul 28, 2015 06:52 AM
Sandman2.0
Jul 21, 2015 09:03 AM
Rider252
Jul 6, 2015 03:37 PM
