Spare Ignition Key
Old Dec 17, 2010 | 08:58 PM
rookie racer's Avatar
Default Spare Ignition Key
Need a spare key , i lost the rubber coated one. any ideas
Old Dec 17, 2010 | 09:02 PM
JCDEYO25's Avatar
As of now do you have any keys for the machine...
John
Old Dec 17, 2010 | 09:29 PM
JCDEYO25's Avatar
Well if you have one of the originals, you can take and get a copy made which is what I did..Also there is a code on the originals if you wanna get another from Polaris..Also copy down the code somewhere in case you lose both originals....If all you have is the 2 originals and they both get lost you have to replace the ignition switch...You can also get those rubber boots for the keys at the stealership...
John
Old Dec 17, 2010 | 11:04 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Helpfull hint for you guys........(If you want it...LOL)
I carry I spare key for both my 450 Sp under the Shift lever handle....
Just pop the Park/rev/high/low.cover off with a flat head driver and place the second key from the dealer in there and snap the plastic cover back on!!!
You will "ALWAYS" have a key with you on the trail or trip you take.......
......Caper.........
Old Dec 17, 2010 | 11:06 PM
How much are those rubber coatings for the keys?
any buy a replacement one yet?
Mine slides through a bit when removed from the Quad also(damaged).
no big deal though to loose your rubber!!....Well the one from your key anyway....LOL
....Caper........
Old Dec 18, 2010 | 04:24 AM
John
I had a key tapped under the seat but i would like to have another one. the number on the key- just take it to dealer?
Old Dec 18, 2010 | 07:28 AM
JCDEYO25's Avatar
I took mine to a locksmith I think...It was cheaper...But yes you could take it to the stealer...lol..
Caper...
I forget how much the trojans were...lol...they weren't much though...
John
Old Dec 23, 2010 | 06:54 PM
guess what ? The snow melted today and i found the polaris key in the driveway yee haw ?
Old Dec 23, 2010 | 07:23 PM
JCDEYO25's Avatar
Nice...make sure to write the code # down somewhere...
John
Old Dec 23, 2010 | 07:44 PM
94harley's Avatar
John
Unless things have changed in the last 2 and a half years since I worked at a dealership, the code will only get you the proper blank for your switch. Not a precut key for your switch.
I was told however from a locksmith in our town that he could cut a key(he has all the blanks on the wall) with nothing more than the code. Which Polaris said couldn't be done. i would recommend making a copy and put it somewhere safe. Cool that you found it to. Awesome luck!!!
