Middle of replacing CV Boots
Old Dec 29, 2010 | 10:40 AM
jeffrey.bandel@atk.com's Avatar
Default Middle of replacing CV Boots
I have everything apart, cleaned and ready for assembly. I have two new boots. The Polaris manual says to install a new snap ring when reassembling. Is there a reason why? The two in there look fine? I really want to put this together today and ride--not spend 2.5 hours driving to the Polaris store.
Also, what about CV grease? Is there anything I can get at the local auto parts store?
Old Dec 29, 2010 | 11:14 AM
TLC's Avatar
TLC
Where did you buy a boot kit with no new clamps or greese?
Never bought a boot alone, but if the clamps look good they should work, I always cut them off. Any normal automotive grease should be fine.
Old Dec 29, 2010 | 12:13 PM
cheapcycleparts.com.
I am referring to the small spring clip inside the cv joint that goes around the shaft.
Old Dec 29, 2010 | 12:34 PM
Polarat's Avatar
I'd re-use the clips if they look good. You should be able to get CV grease at the part store.
Old Dec 29, 2010 | 12:42 PM
thanks. That's kinda of what I thought. Does this need to be synthetic cv grease or is petroleum based OK?
Old Dec 29, 2010 | 02:39 PM
Two Polaris dealars, 3 local auto shops and nobody has cv joint grease. What gives?
Old Dec 29, 2010 | 03:41 PM
TLC's Avatar
TLC
I thought grease is grease. Just pack some synthetic marine grease in there. I also reused those CV spring clips.
Old Dec 29, 2010 | 05:15 PM
Overdrive's Avatar
Wheel bearing grease is too thick for in spec CV joints. I will use it in worn out joints that I want to run a little longer.
Use any thinner grease.
Old Dec 29, 2010 | 06:13 PM
TLC's Avatar
TLC
Wheel being grease is thicker than regular grease ,for sure. I would not use that either.
Old Dec 29, 2010 | 06:18 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
CV grease should be used. Regular grease will destroy the joint. Sythetic is fine but petroleum based is an alternative.
