08 sportsman x2 motor mount
Old Feb 28, 2011 | 01:06 PM
moerules's Avatar
Default 08 sportsman x2 motor mount
well finally got some down time from plowing and tore into the quad to fix the creeping problem. There seems to be a fair amount of movement in the front motor mount about 1" side to side is this right maybe a bit more??? Sure doesnt seem right to me just not sure. I realize it should move a bit to dampen engine vibrations but not that much thanks
Old Feb 28, 2011 | 04:54 PM
moerules's Avatar
Took it apart and mount was shot. Was only part of creeping problem installed new belt and blam all better now!!!!!
Old Feb 28, 2011 | 05:40 PM
Glad you solved your problem.
Old Feb 28, 2011 | 05:46 PM
NoJoke's Avatar
What's the mileage on your '08 and what type of driving do you do?
Old Mar 1, 2011 | 09:00 AM
RickCJ7's Avatar
Did you do a search and install the HD aftermarket mount??
Old Mar 1, 2011 | 11:29 AM
moerules's Avatar
I really just use this machine for plowing snow commercailly and around the yard during the summer. Its has 3600 miles on it!!
As far as the mount I ordered the H/D one but for last night I needed to go down and do a salt session with the quad so I just drilled the rubber out to accept a steel sleeve and bolted it solid until the new one arrives. I does vibrate a bit worse this way but functioned just fine made me 400 last night with it!!!
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
bikedad3
Jul 2, 2015 02:15 AM
