clutch spring colors?
Old Mar 10, 2001 | 05:46 PM
Lurch77's Avatar
I never seen a list for this, so maybe someone can help me.
What is the order of spring colors, from least agressive(lowest engagement), to most agressive(highest engagement)?
My quad came stock with a blue spring, and I added a green one with the RCR kit I got.
Thanks.
Old Mar 10, 2001 | 07:58 PM
AKScrambler's Avatar
Lurch,
I think this link will provide the info you're looking for.
http://www.erlandsonperformance.com/frames5.htm
*EDIT*
I just took a 2nd look and they don't even list green. So maybe it depends on the manufacturer. A little help... Anybody?
Old Mar 10, 2001 | 08:01 PM
SHAGGY500HO's Avatar
MILLENIUMSCR500 HAS A POST (HPD ?????) THAT HAS A LINK WITH A DYNO CHART AND UNDER THE CHART IS A LIST OF HPD SPRINGS
Old Mar 10, 2001 | 08:21 PM
01scrambler's Avatar
Do the ATV's use the same size springs as the snowmobiles? I know you can get a chart of them from your dealer or if your lucky you can find it on the polarisindustries site. I don't know if there the same or not, I'm just kind of getting into fourwheelers thinking about buying one soon.
Old Mar 10, 2001 | 08:53 PM
MilleniumScr500's Avatar
Hey Lurch77 here is the link just check the dyno chart and underneath there is a primary spring chart but it is only for HPD springs hope this helps.
http://ca.photos.yahoo.com/bc/ssjb1c...l=fld1&.src=ph
Have a good one
Old Mar 10, 2001 | 09:12 PM
Lurch77's Avatar
Thanks everyone. I have a little better feel for it now.
Old Mar 11, 2001 | 03:10 PM
Farmr123's Avatar
I actually have a chart showing the different spring colors and strengths. It shows both engagement force and full shift-out force. If you still want more info, e-mail me directly and I can scan it and e-mail it back.
sjb@cornhusker.net
Old Mar 11, 2001 | 06:40 PM
Englishmatt's Avatar
No the sled springs are totally different .The best graph on springs is in the workshop manual from Polaris, it even list's each ones part # and torque values.
Matt
2000 500 Scrambler.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Schneider
Jul 24, 2015 05:05 PM
coolguy420
Jul 10, 2015 01:17 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
