oil plug leak?
Old Mar 19, 2011 | 01:44 PM
lawns90's Avatar
Default oil plug leak?
Hey guys,
All of you have been helpfull when I had a problem. I have a 2002 polaris 400 sportsman. I went to change the oil simple job. I reinstalled the drain plug and plastic washer in the plastic oil tank and it was leaking very slow. Replaced the plastic washer with a stainless from the dealer and still have a very little comming out. Any ideas? Thanks
Old Mar 19, 2011 | 01:56 PM
NoJoke's Avatar
Try some Teflon plumbers tape on the threads of the drain plug........
Old Mar 19, 2011 | 04:40 PM
Originally Posted by lawns90
Hey guys,
If you over tighten the drain bolt and washer and a new washer doesnt help,then the insert in the tank can be damaged and can move causing dripping also. Had a couple of these happen from owners that did their own service! Drain bolt just needs to be snug,don't crank down tight. OPT
Old Mar 19, 2011 | 06:00 PM
MYWAYOUT's Avatar
Had the same thing happen on my 400... The insert has failed and will leak. A temporary fix would be an oversized rubber washer that covers the outer edge of the insert.. Garden hose washer??? I think I made my own out of something I had lying around... Worked until I could buy a new one.. Hope this helps...
Old Mar 19, 2011 | 06:40 PM
lawns90's Avatar
to my way out,
do you have to buy a new tank or can you buy the insert?
Old Mar 20, 2011 | 09:38 AM
MYWAYOUT's Avatar
You will have to buy a new tank... The insert is molded into the tank and once it has been unseated it leaks. I still have my old one... I was going to look into having it machined out and options to put a new one in... but wanted to ride instead...
Old Mar 20, 2011 | 10:50 PM
4getful2's Avatar
That is a problem area ,on those plastic tanks. You may want to consider a used one off of an older unit that used aluminum tanks,lasts forever.
try e-bay
Old Mar 21, 2011 | 09:43 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
try e-bay
Yep, what he said!
Old Mar 23, 2011 | 06:22 PM
lawns90's Avatar
Thank guys,
The oil was leaking from the oil plug so I put some high temp gasket maker around the plug before puting it back on. No more leak.
Old Mar 23, 2011 | 06:53 PM
TLC's Avatar
TLC
Another Polaris improvement, "let go from aluminum alloy oil tanks over to plastic like we did with the roller cages."
I swear Polaris has stock options in a plastic manufacturing plant somewhere.
slowgsxr97
Mar 18, 2022 03:40 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Captjay
Jul 23, 2015 12:33 PM
Unzzy66
Jul 11, 2015 10:01 PM
