05 SP500 fitted with 08 SP800 Drive Clutch Need belt help!
Hey Guys! I just replaced the EBS drive clutch on my 2005 Sportsman with a new 2008 Sportsman 800 EBS clutch. When I put it together with the new belt I used belt part number 3211095, which is the same belt part number for the 2005 SP500, and the belt isnt very tight and I can spin the driven clutch and the belt slips on the one way EBS brake. The belt is riding correctly on the driven clutch according to my service manual. Is it possible I need a slightly shorter belt? If so does anyone know the part number? I also looked into the belt for a 2008 SP800 and it is part number 3211113 and I believe it is the same belt length so I dont think that will help any. Anyone have any ideas???
The belt number 3211113 should be correct for the later models with EBS. Did you change out the secondary clutch as well? I'm not sure if it will make any difference but, The 07-09 EBS will be a roller style secondary clutch, not the conventional style your accustomed to seeing on the older machines.
I did not replace the secondary. It is the OEM secondary that came on the 2005 SP500 when I purchased it new. I'll look at purchasing the belt you suggested. Let me know if anyone else has any pointers. Thanks again!!
Even though your 05 has a secondary that is for EBS it may be different from an 08. There was some changes on later models with EBS. Yours should have buttons vs the later EBS models have a roller type set-up. As stated before, the sheaves might be different. I'm not 100% for sure. A slight difference in the pitch of the sheave can make a difference.
the primary clutches may have differnt diameters as well or at the least the center differnce measurement might be closer on the 800 vs the 500? just guessing though.
That Kind-a sucks! I was hoping I could use my 2005 SP500 EBS secondary. Now I need to tell my bride I'm spending more money on the ATV... Ouch! i looked on e-bay and there is one '08 SP800 secondary or $199 (buy it now), but I'm always afraid these used clutches will need to be rebuilt. Looks like a new 2008 SP800 secondary fully set up will run about $550. sheez!
trouttracker
Jul 20, 2015 11:54 AM
