polaris sportsman lift kit and axles
Old Mar 15, 2016 | 03:20 PM
WilliamBos's Avatar
Originally Posted by greg74
I guess on a Sportsman 500, you can't go with much bigger tires than stock before you need a lift? Most 4x4 quads have a little extra room without having to lift them. A Grizzly has 25" stock tires, I could probably go with 27's without changing anything. The stock 25" size is big enough for me though. The original poster said he wasn't going to run bigger tires, what's the point of adding a lift at all then? A guy I work with put a about a 3" lift on his 01 F150 4x4 but couldn't afford to buy larger tires so he simply has a lifted truck with stock tires on it. Made no sense at all to me. Why put a lift on anything if you're not going to put bigger tires on it? All that extra stress on driveline components but no gain in ground clearance. Not to mention making it handle and drive worse.
Lift kits are not just to stuff bigger tires under something. You want a tire that will not rub at maximum articulation, its a balance. Just the right tire for the lift.
Now if you lift your 500 you will want to add wherl spacers to your shopping list, its gonna feel tippy if you dont, or different offset wheels.
Get 27"tires, may need trimming and a clutch kit.
bzdok1234
30
Feb 23, 2016 01:55 PM
coldnorthpol
Jul 14, 2015 11:22 PM
Mikea1978
Jul 4, 2015 12:37 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
