96 Polaris sportsman
Hi everyone,..
I'm a newcomer to forums and also to owning a Polaris atv., though have ridden them over the years and am looking forward to learning and possibly helping others in the future also.
I have a second hand 96 Polaris sportsman 500,.. I've had troubles previously with the air box with air flow into it,..it had 2 holes cut out on the cover and wouldn't go at all until we covered them over and sealed it shut and was running great,...until recently. (Are they designed to be vacuum sealed like that or do they need extra air flow to box)..?
The bike takes off great and gets to a certain rev and speed and will only stay at that speed,.. if I keep accelerating it bogs down. We've checked fuel lines, carbi and are at a loss to identify problem. Can anyone help..?
Hi everyone,..
It wasn't the cam,..it wasn't the air box either, even though its getting replaced asap.
It was the 3 Buttons,.. not on the clutch,..but rather the rear one that has a spring in it,..it was all jammed up,..took forever to get it free and cleaned it up and replaced buttons. $10 job, though months of "head twist".Thats why the belt was fraying cause the front was pushing in and out but not the rear, and the revs hitting the limiter.
Thanks alot You guys are brilliant,.. "couldn't have done it without the advice".
Ps: taking out to the mountains tomoro night for a ride cant wait,.. tested it,..The Monster screams, runs better than before.
I never changed the buttons before even on our 97 SP500 with 7500 miles that still runs like it did from new. I wonder if I should just change them anyways and beat the problem to the punch?
BTW if it was the Cam lobe problem the major symptom is backfiring through the carb but we have not ran into that one yet as well.
