weight
Old Mar 11, 2001 | 12:46 PM
trlblazr250's Avatar
how could i lightn the weight of my trail blazer enough to make a difference? and how much would a 1 tooth lower sprocket make a difference?
Old Mar 11, 2001 | 03:00 PM
derekhonda's Avatar
not at all. Youd be better off going on a diet, be alot cheaper
Old Mar 11, 2001 | 11:51 PM
CaptNemo's Avatar
Going to pre-mix and eliminating the oil injection will drop around 10 lbs. I took 23 lbs. off of my chassis ( NOT the Scambler ) in the last month and feel alot better. I know that the quad will appreciate the lighter load...
Old Mar 12, 2001 | 11:19 PM
00TB250's Avatar
Removing the battery and starter would be a big weight savings. Mine start's surprisingly easy with the pull start, but don't know if it's really worth the inconvenience. I think I heard someone say that 7lbs. is worth 1hp.?
Old Mar 13, 2001 | 10:27 AM
Tim1's Avatar
I use to tell everyone to get rid of the oil injection to play it safe.But someone told me that the oil injection system adjust it's self through out the power band.It sets it,s self at 80:1 at idle,50:1 in the middle and 20:1 at full throttle.He said mixed the gas at 50:1 will cause it to be to rich at idle and to lean at wide open throttle.Is this true?
shimanok2
Jan 29, 2016 07:37 PM
Robinhood
Dec 26, 2015 10:28 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
