02 polaris stock warn winch
Old Jun 2, 2011 | 12:41 PM
4chevys4me's Avatar
Default 02 polaris stock warn winch
02 polaris sportsman 500 HO stock winch. Works well in and out. Just can not get it to free spool off. I must push the out button and pull at the same time. Is there w way to clean them? I have never had one apart. Any help would be great.
Old Jun 2, 2011 | 12:52 PM
Does the **** on the winch to lock and unlock work?? Should just be able to unlock and you should be able to free wheel the winch cable out,IF I'm understanding you correctly?? OPT
Old Jun 2, 2011 | 01:00 PM
4chevys4me's Avatar
**** on end will not turn
Old Jun 2, 2011 | 02:17 PM
mudslinger2's Avatar
I haven't been stuck since the last time!
Default Clean it out
Tear into it! I have one of the 1500s with the little cam switch to freespool-mine was stuck in freespool. I took it apart and cleaned it all out-really a cheap design and very simple when you get in there!
Old Jun 2, 2011 | 03:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like you need to take it apart and clean and lube it. it should be fine afgter that i'm guessing.
Old Jun 3, 2011 | 09:02 AM
4chevys4me's Avatar
OK, went out this morning and the free wheel lever on the end just spins all the way around freely. Does not disengage the spool. I have tried to look up the manual on ling, but all I can find is that it is discontinued. Warn 2500 2.5 ci is all I can find printed on it as it sits on the quad? Any thoughts?
Old Jun 3, 2011 | 02:13 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like something broke in side for sure. you'll have to take it apart to check it or live w/ spooling out w/ the switch(a major PIA i would think). once you find out what is broke you should be able to get a replacement part. maybe email warn and ask if you can get parts. just a thought.
Cole Hadden
Jun 15, 2025 09:05 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
