Replacement Axles
Old Jun 29, 2011 | 04:35 PM
Spdecat's Avatar
Default Replacement Axles
I'm going to replace both front Axles complete as there starting to click and I think it's time . Question besides the dealer who want's $399 each I can get STI Axles for around $170 each there manufactured by Interparts . Has anyone used or heard of these axels any good or bad .
Old Jun 29, 2011 | 04:40 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you check ebay or the cv man? find good prices most of the time.
Old Jun 29, 2011 | 05:10 PM
Spdecat's Avatar
Thanks I'll check the CV man .
Old Jul 1, 2011 | 10:26 AM
EPIChad's Avatar
EPI offers axles for most machines. There are a quality replacement axle. You can normally get a complete shaft, half shaft (outer cv joint and axle, or just the cv joints if needed. www.epiperformance.com
Old Jul 1, 2011 | 06:43 PM
Spdecat's Avatar
I already checked them out , they don't have a set for my machine . I'm ordering a set Monday Interparts have the lead but I'm still researching . I wish stock was a little cheeper than $399 each .
Old Jul 2, 2011 | 09:54 AM
Spdecat's Avatar
Anyone else know of a good quality company the deals in atv axles . I'v checked EPI and SuperATV-Rhino both don't sell complete axles for my machine . CV man does but I spent a hour reading horror stories about his axles thus I'm keeping away . And I don't need Gorilla's I'm now thinking of changing all 4 .
Old Jul 5, 2011 | 08:27 AM
EPIChad's Avatar
Thanks for checking with EPI. We are always adding new parts and usually add a big group in the fall after summer testing.
I did check and we do have all four cv joint rebuild kits. So if you cv joint housing are in good shape you could rebuild them that way. Its a little more work but gives you another option. The rebuild kit will rebuild the OE joints only. It will have a ball bearings, cage and race, cv boot, clamps and grease pack.
Old Jul 5, 2011 | 09:15 AM
Spdecat's Avatar
Thank's I ended up buying some other's and when they wear out or before I'm selling the quad and buying a new one . With the amount of miles I have on it I wanted to replace the complete axle shaft and all . I'm now renting tho a set of torches to blow holes in my steel inner cv cup so I can drop a bolt down and attach a slide hammer . After 3 days now I can't remove my axles both sides pulled apart ( what a pain ) fronts came apart no problem .
Old Jul 5, 2011 | 09:27 AM
EPIChad's Avatar
The rears can be a big pain!! Between a slide hammer, some pry bars, penetrating fluid, and a few cus words they will eventually come out (I hope). Good Luck!
toonces
Jul 28, 2015 01:58 PM
Schneider
Jul 24, 2015 05:05 PM
trouttracker
Jul 20, 2015 11:54 AM
Rider252
Jul 6, 2015 03:37 PM
jettman
Jul 6, 2015 12:16 PM
