AWD Doesn't Work On 2004 Polaris Sportsman 400
as he just mentioned, unless your bike is in reverse, it should not be reading slow, this shold only flash that while it's in reverse w/ the override pushed. by sounds, your bike doesn't have the hubs and has the hillard style fornt end awd.
As well as the Speedo, the AWD light on the switch must work also. I never tried the speedo by pass trick but I hear it works. I would try it it before buying a $300 speedo also.
Here is the best info about it by "Ditchdigger" I could find on it. http://forums.atvconnection.com/pola...dont-work.html
if everything is working on the speedo, then maybe the speed sensor on the wheel is bad and thats why your speedo isn't working. chances are if your screen is flashing slow only when your in reverse, then i would say the tranny switch is working correctly. you might even want to take apart the awd switch it self to check for corsion of some sort. worth a try. if you ground out the correct wire in the pod off the speedo, then the awd should be bypassed making it work even w/ a bad speedometer.
I took the plug loose from the AWD switch and cleaned, did not help. I also tried grounding the Brown/White wire from the AWD switch, did not work either. I guess that Brown/White wire is in the harness from the AWD switch? If not, is there one in the large plug on the back of the speedo? You mentioned the sensor could be bad. Where is it located?
The "Hall Effect" sensor is located by the front right brake rotor, it sends the distant/speed info by wire to the speedo.
A bad wheel sensor does not effect the awd though. I have been running around with a dead wheel sensor for 3 years now. Only my hour meter works on my speedo but my AWD is fine.
