Sportsman 500 EFI to Carburetor
Old Jul 14, 2011 | 08:40 PM
Newfygarge's Avatar
Default Sportsman 500 EFI to Carburetor
Can a 500 motor off a 2007 EFI go right into a 2001 500(after the motor is taken out), or are there some changes that have to be made. Thanx in advance
Old Jul 15, 2011 | 01:29 AM
TLC's Avatar
TLC
The Fuji motor never changed, there fuel intakes for throttle body or carb should be the only difference I would think.
Old Jul 15, 2011 | 02:24 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you should be able to change it. you might have to fool around w/ jetting a little and the exhaust might be a little differnt. just guessing.
Old Jul 15, 2011 | 05:50 AM
Newfygarge's Avatar
Thanx, so no changing of cylinder head is needed
Old Jul 15, 2011 | 06:52 AM
TLC's Avatar
TLC
Except for one gets its fuel/air mixture by a 39mm throttle body and the other a 40mm carb, the motors are the same.
Top Pic is a 2007 efi and the lower pic is a 2001 H.O the intakes for carb and EFI. Parts #37 and #38 are the only difference.
2007 500 EFI
2001 500 H.O
Old Jul 15, 2011 | 10:42 AM
Newfygarge's Avatar
Thanx TLC
Cummins Driver
Sep 11, 2019 01:22 PM
WesTech
11
Aug 11, 2015 07:55 AM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Shifts
14
Jul 13, 2015 08:41 AM
