scrambler gear grind
Old Aug 16, 2011 | 07:53 AM
TLC's Avatar
TLC
Not sure how the clutch have anything to do with his problem. The shift lever's linkage rods lead to the tranny. If there is any grinding it will all be in the tranny.
Old Aug 17, 2011 | 02:11 AM
Originally Posted by dom088
we have done all of that.. seemed in fine condition to me...
once i stop the secondary from spinning it will shift into gear without grinds.... it spins too fast by itself.... it has to slow down...
idle is really low.
Did you replace the driven clutch ramp buttons? ,using OEM belt or after market? If rear clutch is spinning it will grind when you try to change gears. Plus if clutches are out of alignment will cause belt to ride on drive clutch inner or outer sheath causing the rear clutch to keep spinning. OPT
ghost civic
Jan 15, 2020 07:43 AM
Divergent12
Dec 30, 2017 08:33 PM
austinwhitton
Aug 11, 2015 06:21 PM
djoshuah
Aug 5, 2015 10:59 AM
maxjung
Jul 13, 2015 05:11 PM
