carb adjust on Sportman 600 twin
If you mess with it count the number of turns to lightly seated in first! This is the fuel/air screw and is normally sealed off from the factory with a plug unless tampered with. Depends on altitude but should be between 2-3 turns out. Controls mainly the idle circuit and is best fine tuned with a carb adjuster that you can adjust while running. OPT
micheleLeigh
07-12-2015 02:50 AM
07-07-2015 11:00 PM
