'05 Phoenix Exploded CDI
Old Aug 29, 2011 | 09:57 AM
tjewett's Avatar
Default '05 Phoenix Exploded CDI
First Post! I've got a 2005 Phoenix that had blown the back out of the CDI. I replaced the CDI with a new one and it started right up. When I tried to ride it and opened up the throttle the CDI blew out again! Before I blow another $150 CDI i thought I'd run this past you guys to see if it might be something else causing it to blow... Rectifier? Thanks a lot !
Old Aug 29, 2011 | 11:13 AM
Might have the stator checked out as the cdi gets its input from it.Charging on different part of the stator,but could be shorting out,plus do a resistance check on the reg/rectifier also.If you can't find the specs,rule of thumb on reg/rectifier is on all yellow wires between each other should show about the same resistance,plus none should be shorted to ground. OPT
Old Aug 29, 2011 | 12:08 PM
HMT Racing's Avatar
I had a phoenix do the same thing, rectifier was bad. Replaced and all has been good
Dabears1983
Jun 23, 2015 04:59 AM
bowhunter38
Jun 14, 2015 04:38 PM
Jun 10, 2015 11:20 PM
