quick question
Old Sep 20, 2011 | 10:04 AM
awr90's Avatar
Default quick question
Ok so I got my predator back from the shop and there is NO up and down play in my lower rod bearing. There is a little side to side and I have read thats normal. The thing that I'm wondering is....is it normal for the flywheel to have some slight side to side slack? When It grab i and turn it I can feel a little bit of slack there before the engine rotates. It seems normal but I want to be sure.
Old Sep 20, 2011 | 10:16 AM
awr90's Avatar
Also how can I tell if I have a bent valve?
Old Sep 20, 2011 | 03:01 PM
Doctorturbo's Avatar
GOT BOOST!
If you have the head off, just prop it up so the port is up and pour any type of solvent into the port.
See if it leaks out. If so, will there you go.
If the engine is together then do a leakdown.
cornermike
Sep 10, 2015 08:30 AM
Albertaboyy
Sep 9, 2015 09:51 AM
Rooky
Sep 9, 2015 03:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
