Valve lash for hawkeye
Old Sep 21, 2011 | 12:45 PM
wlvrn's Avatar
Default Valve lash for hawkeye
I have an 06 hawkeye 4x4. When it gets hot it sputters like it aint gettin enuff gas. I have checked the jets and all seems good I want to check the valve but dont know what they shud b set to. Does anyone know what they should be? Also how to I find tdc so I can check the timming?
Old Sep 21, 2011 | 03:52 PM
Remove the cylinder head valve cover, pull recoil slowly(easier if you remove the spark plug) until you see the intake valve rocker arm go down and start to come up,then look at the cam sprocket and when the sprocket locating pin is straight up on the head this is TDC! Then you can check the valve clearance(.006 intake and exhaust) Engine must be cold to accurately check!! OPT
Old Sep 21, 2011 | 07:23 PM
wlvrn's Avatar
Thanks! The valves were .110! Test drive now thanks again
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
