2008 Sportsman 800 EFI Grinds Into Reverse.
Sounds to me like the "clunk" you hear is just the clutch engaging. As for the grinding, if it doesn't fully shift into gear then you will get a grinding. Just the same as in your car. I have had that happen on all of my machines when I don't quite get it shifted all the way in. Very seldom has this happened to me. If it is a common issue for you then it sounds like and adjustment problem. Never tried to make any adjustments to my shift linkage before. If I remember right where the shift rod connects to the linkage on the trans. it was a flat plate with 3-4? holes in it that you could move the shift rod to. Like I said, never tried before but maybe something worth trying???
bzdok1234
30
Feb 23, 2016 01:55 PM
