2007 hawkeye speedometer
Old Oct 10, 2011 | 09:18 AM
carolinabomb's Avatar
Default 2007 hawkeye speedometer
Just bought my son a 2007 hawkeye with 17 hours on it. I is running great, but after the 4th day, the speedometer goes to 188 for a couple of seconds and N & R lights flash. Any idea what would cause this? thanks for help. d
Old Oct 10, 2011 | 01:16 PM
Welcome to the forum! Check that battery connections are tight and when running make sure its charging 14-14.5 volts(or thereabouts on the Hawkeye). Check electrical connector and wiring on the transmission gear selector(Could be shorting out/bad gear selector switch?) OPT
Old Oct 10, 2011 | 01:33 PM
thanks for the information, I will check it as soon as I get home. Is the switch located near the gear shift lever?
Old Oct 10, 2011 | 01:55 PM
Located on the transmission! OPT
Old Oct 10, 2011 | 02:07 PM
thanks OPT!
Old Oct 10, 2011 | 06:36 PM
The neg battery cable was loose. Thanks again opt! that fixed it.
Sep 23, 2015 06:23 AM
braap123
Sep 7, 2015 12:58 PM
rawbdiggity
Sep 7, 2015 12:05 PM
braap123
Sep 7, 2015 10:57 AM
snowolson
Aug 31, 2015 03:51 PM
