ebs
Old Oct 16, 2011 | 08:15 AM
wayout's Avatar
Default ebs
every now and again my ebs doesn't work,anybody know what could be causing this,i'm thinking it might be my belt, i put it threw the mill this past winter...........
Old Oct 16, 2011 | 09:15 AM
reno82's Avatar
Does this happen after going through water? Mine will slip if water splashes in on deep crossings. Need to let it dry so you don't burn the belt. Does sound like a belt problem either way.
Old Oct 16, 2011 | 04:40 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
could be the one way bearing failing and letting it free roll if it's not belt slip, but you should feel belt slip when your under power even more.
Old Oct 19, 2011 | 08:16 AM
TLC's Avatar
TLC
Here is how you check the EBS bearing out. Changeing belt POLARIS ATV - YouTube
