allignment
Old Oct 27, 2011 | 09:35 PM
irinman2424's Avatar
Default allignment
can anyone help me with how I might be able to align the front tires on my 2011 sportsman 500? I noticed since I got it back from the shop its pulling to the left a little bit not bad just enough to have to constantly put a little pressure to the right. if riding slow one handed it can wear ya out pretty fast
Old Oct 28, 2011 | 12:03 AM
Make sure all tires have equal pressure.(this can cause it to pull to one side also if rear tires are different pressure)Have someone hold bars straight,use a straight edge if you don't trust your eyes! Line up front tire with rear,then toe out the front tires 3/8" at the front edge. Try this and see if it helps. You may have to do this a couple times if still pulls sometimes to compensate for tie rod end wear, tire wear,etc. PS a lot of times you can notice one tire that may be causing the trouble and only have to adjust that one!. OPT
Old Oct 28, 2011 | 07:11 AM
"out the front tires 3/8" at the front edge" just so I make sure I understand if sitting on it or looking down at the tires from above it would look something like this
that would be leading the toe out in front
or are you saying creating a gap in the front leading edge so the tires would be like this
Old Oct 28, 2011 | 01:05 PM
user493's Avatar
Moto Psycho
Toe out.
Old Oct 28, 2011 | 02:58 PM
ok thanks for clerifying that for me just wanted to make sure I was going the right way with it
Old Oct 29, 2011 | 01:07 AM
bigcam400's Avatar
jack both wheels up just nuff to spin freely,..take a flat head screw driver an get tire spinning pretty fast an use screw driver to "scrib" a line around center of tire tread,..pull jacks out,..now measure from line to line at 3 an 6 oclock positions,..want bout 3/8s more on front side!! this is how race teams do it....
Old Oct 29, 2011 | 09:37 AM
joeboo151's Avatar
So i struggled with this a couple weeks ago their seems to be some discrepancies from what I have found doing a search on the web. I also get two different measurement if I have machine lifted so tires just touch vrs on the ground with driver. My question is what is the proper way and what should the end result be with driver on machine.
Old Oct 29, 2011 | 09:42 AM
bigcam400's Avatar
should be on the ground at ride height with weight it will carry on it...
Old Oct 29, 2011 | 09:50 AM
joeboo151's Avatar
Thanks and be toed out my clymer book says toe in but they also say to have tires just off ground what wi
ll the effect be while riding toe in vrs out
Old Oct 29, 2011 | 09:57 AM
bigcam400's Avatar
toed in probably be darty an irratic...toed in with front in off ground might be ok,..if when suspinsion levels with weight might line up to toed out specs?? idk,..always do it on ground at ride height!! know whats what then....good luck!
