2004 Sportsman 700
Old Nov 2, 2011 | 07:47 AM
Chopper400ex's Avatar
Default 2004 Sportsman 700
I bought a 2004 carb 700 from a guy for $1900. A dealer told him (without taking it off the trailer) that it needed a new cam. I noticed that the intake boot was cracked so I bought it. I replace the intake boot and the boot between the carb and airbox. I cleaned the carb, and replaced the plugs. It is running 100x better, but it seems like it revs really slowly. It's like you would be in a gear that is to high, but it does it even when you are in neutral, or park. Could it still need a cam, or maybe a piece of crap got into the carb again? I did remove the exhaust and it seems to be freee and clear.
Thanks
Old Nov 2, 2011 | 09:17 AM
Look under the front panel and see if you have a separate cdi and coil,OR if you have what is called a coil pack with the two plug wires and says DUCATI on it and no cdi module. Early build 2004 700s had the Ducati system which was prone to have problems! If you have the later separate coil and cdi system, then you might pull the clutch cover and check the belt and clutches(If in doubt just pull up on the belt,roll it off the clutches,crank atv and see if if revs out then. Keep us updated! OPT
Old Nov 2, 2011 | 09:27 AM
Sorry I forgot to mention that it does have the Kokusan cdi. I will try pulling the belt, thanks for the info!!
Old Nov 7, 2011 | 01:29 PM
Finally got back to the wheeler. Removed the bowl and checked/cleeaned the jets. I removed the belt and didn't notice a change in the reving. The clutch does look pretty dirty, and the spring seems to be a little soft. Can these primary clutch be pushed in fairly easily?
Thanx
Chopper
Jmuddin284
Jan 19, 2026 07:16 AM
COFatboy
May 2, 2020 12:06 AM
velcro7279
Aug 24, 2015 01:15 PM
bradco
Aug 21, 2015 08:11 PM
Stirling
Aug 9, 2015 01:49 PM
