Cooling Fan
Old Nov 7, 2011 | 01:16 PM
buzzshep62's Avatar
Default Cooling Fan
I have a 2007 Polaris Sportsman 500 EFI. I'm getting a code 58. The fan will come on and shut off. Seems to have good RPM. I have cleaned the plug, but still get the code 58. any suggestions?
Thanks
Buzz
Old Nov 7, 2011 | 04:07 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i couldn't find the code 58 in the manual. but if you unhook the sensor wire harness and turn the key to the on (not start it) the fan should come on and stay on. if it does the fan is working correctly and may be a bad sensor. also check for correct amount of coolant as it will effect running of the fan correctly as well as of air in the system.
Old Nov 8, 2011 | 07:48 PM
Kerbbirds's Avatar
pdm controls fan and charging on efi models
IMLN
Sep 28, 2015 03:32 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
alzgarvin
Sep 11, 2015 08:53 AM
lancemll88
Sep 5, 2015 03:16 AM
