Heated Grips (what does everyone else have)
Old Nov 13, 2011 | 06:33 PM
cscotter's Avatar
Default Heated Grips (what does everyone else have)
Hello
I just started looking into getting some handwarmers on the atv.
Has anyone found a setup they like, or dont like??
I dont know much about them yet. I looked on the polaris site, they have a kit for $55 that has a heat strip that goes under the grip and says "all wiring included" it looks like the wires have crimp ends already on them like there is a place they may plug into?? I cant tell if it comes with a on/off switch though??
Any help appreciated
Old Nov 13, 2011 | 06:51 PM
Plumberjim's Avatar
Default Heated grips
I got the Polaris ones. Mine came with a switch and were very easy to install. Use an air compressor to balloon on/off your grips. The wiring was pretty easy. I used mine today and they still work great after a few seasons with them.
Jim
Old Nov 13, 2011 | 07:14 PM
cscotter's Avatar
Plumberjim
Does the switch mount to the handlebar somewhere?
So after u get the factory grips off, you are able to reuse them and put them back on over the heat pad???
What keeps the heat pad attached to the bars when you slide the grip back on??
What did you use to plug the hole on the grip you were blowing off with the compressor??
Thanks, ElectricianCscotter
Old Nov 13, 2011 | 07:17 PM
AtvMinibike's Avatar
Got Ducks Unlimited Hand Warmers with Extra large size for easy mounting.ordered them online 6 mos ago. I am happy with it.
Old Nov 13, 2011 | 08:16 PM
Plumberjim's Avatar
The switch is mounted in my headlight pod.
The heating element has a sticky back which sticks to the handlebars.
To get the grips off, I stick a blower nozzle from the air compressor in the hole on the outside of the grip and pinch of the inside of the grip with my other hand and it will balloon up making it able to slide off.
Yes I used my same grips over again.
Jim
Old Nov 13, 2011 | 08:25 PM
cscotter's Avatar
plumberjim
Does the switch with the polaris kit fit into one of the rectangular Knockouts on the headlight pod?? Did the switch come with the kit?? That would be great.
I added the backup lights, and it came with a switch that fit right into the pod cutout. I think there is a space for another switch.
Old Nov 13, 2011 | 10:33 PM
awsume800efi's Avatar
Originally Posted by cscotter
plumberjim
yes the switch fits right in those rectangular slots in the pod at least on the xp pods they do i have the polaris hand warmers and the switch comes with and has a high off and low setting mine work real well
Old Nov 13, 2011 | 11:12 PM
user493's Avatar
Moto Psycho
My thumb is the only thing that gets cold so I just have a thumb warmer.
Old Nov 14, 2011 | 12:46 AM
medic2491's Avatar
I have the polaris ones. They were installed when I bought it. They are very good.
Old Nov 14, 2011 | 05:36 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
I have the polaris warmers as well and love them. Took about 30min to install. They make them with two different switches that I could tell. The rectangular that fits into the knock out in the pod and a round switch which you have to drill a hole. Either one is fine but the rectangular one looks better.IMO Very simple to wire, You can feed power off the 12V outlet in the light pod.
