No charge for 2006 big boss 6 wheeler
welcome to the forum. did you do a voltage check to see what the voltage is? sounds like it could be the recifier that is bad or maybe bad/corroded connection. the recifier is what controls the amount of voltage put out. if that is not the problem then my guess the stator is the isue. check connections first guessing, but it should be mounted up under the front end, it's square and thin and has most likely 4 or more wires plugged into it. hope this helps.
oliveiracarlos
19
11-11-2015 05:49 AM
craacker
09-09-2015 04:32 AM
Elkaholic
09-06-2015 02:44 PM
