K&N Filter
Old Mar 16, 2001 | 02:21 AM
Rhunzi's Avatar
does the K&N filter do much for the increase of power for the SP500HO. the one for my truck made a big improvement. just would like to know if there is a improvement.
2001 SP500HO Bad A** Yellow Beast
Old Mar 16, 2001 | 09:58 AM
TheQuadfather's Avatar
It will breath better, and filter better, of course. You won't be able to tell much difference in the way of performance. You can really tell a difference on a two stroke, but not much on a four stroker.
Old Mar 16, 2001 | 10:28 AM
polarisz71's Avatar
I'm doing the same for my 98 SP500. I put one on my Chevy Z71 and it helped out alot.
Old Mar 16, 2001 | 10:45 AM
DieselPro's Avatar
Do an oil analysis on your truck and you'll see that the silicon levels are high!
The passing of dirt through the K&N is also evidenced by dirt residue after the filter in the intake tract. If you've run one for any length of time, it WILL be there.
The Uni filter is a better choice IMHO
Old Mar 16, 2001 | 03:38 PM
shakeyjake69's Avatar
I also agree that the Uni is better for your atv. It also gives about the same amount of perf. The uni is also alot cheaper.
Old Mar 17, 2001 | 12:23 PM
subfan's Avatar
Will this happen with the Outerwear over the filter? My SP500 RSE came with an Outerwear on the stock air filter. I put one on the K&N to be on the safe side. I think they are waterproof too.
Old Mar 18, 2001 | 02:03 AM
Rhunzi's Avatar
does anyone know the price of the K&N and the UNI
Old Mar 18, 2001 | 02:15 AM
subfan's Avatar
K&N = $31.99 at Rockymountainatv.com
Old Mar 18, 2001 | 03:04 AM
Average price of a Uni-Filter-$15-$17
Old Mar 18, 2001 | 03:19 AM
Englishmatt's Avatar
If you live in a temperate climate go with the K&N but if you use your machine in dry dusty climates you will need the foam oil soaked Uni.
I live in B.C Canada and the K&N is perfect the uni is to much so figure out were your running your machine and for the price of the filter's try both.
Matt
2000 500 Scrambler
