Tired of tires going flat?
back when i ran heavy equipment such as Caterpillar front end loaders, we'd put a gallon or two of coolant in the tires, when it's not beaded up, to help keep the inside of the wheel from oxidizing from the wet air inside. plus it did lubricate the bead a little under the extreme weight. for some of the smaller front end loaders, we put liquid calcium in the rear tires for weight.
Ethylene glycol is the "old" green cooland tha propylene glycol is the newer extended life coolant that they claim is less or "none" toxic.
The MSDS (material safety data sheet) lists 40-60% propylene glycol by weight.
Personally I wouldn't drink Slime either.
http://www.slime.com/wp-content/uplo...t-New-MSDS.pdf
Mine always leaked and need air ever few months. The slime totaly fix it and I have not added air in a year and a half. Who cares if there is a mess inside, when these tires come off there trash anyways.
A tire shop changes my tires so its there problem anyways. LOL
#15
I would think coolant in your tire would mess the bead up-
bead sealer is glue- to seal and keep the bead on the rim- coolant is not glue and has lubricating additives in it, it will only lube the bead, which would make the bead "slip" off easier if it gets pinched in a rock or something... I would think
ever try to take a sealed bead off a rim? it's a major PITA to break that bead-
I also can't see why coolant would "seal" any leak permanently- a tire is rubber, same as a radiator hose. Coolant won't seal any radiator leaks- hot or cold... so don't know why the coolant chemistry would effect the tire rubber any different then the radiator rubber
but I could be wrong.
#16
#17
Why does that matter, it goes in your tires not on your dinner plate.
ATVs also use gas and oil which no one would want to drink either.
#18
We would break the beads on the tire machine,BUT take em to a table and while I or someone else held the tire,another guy would use tire irons to remove the wheel and try not to splash this crap everywhere! We held the tire up right until we got it outside on the used tire pile! I've seen some with over 5 pounds of tire slime and about 20 tire plugs!
The best sealant we found down here was in 5 gallon pump cans from Texas Refinery Corp and mainly used for tractor tires and industrial tire sealant.(TIRE SEAL 11 (contained a little antifreeze to protect the rims from oxidation) Worked pretty good (plugged holes up to about 5/16" or a little smaller than your little finger! Easy to pump in,but ALL tire slime is nasty!
OPT
#19
So coolant keeps the aluminum wheels from oxidizing preventing the tire to leak around the bead. Makes perfect since to me but...... what about when I pick up a thorn or another sharp object out on the trail or roadway? Will the coolant help me out then? I'm kinda doubting it. As messy as slime can be I'll stick with it. Besides, How often does the average guy change out tires on their quad, bike, tractor, etc.
#20
Most of the good tire sealant has a little antifreeze in it to prevent rim oxidation(check specs on Tire Seal 11 from Texas Refinery Corp), BUT straight coolant won't help do anything but have clean rims for you when you have to tear the tire off to plug patch it!
I've even found coffee grounds with antifreeze that some guy concocted and swore by it,but had plugs all over the tire! Tire sealant is nasty but pretty well does the job on small to medium punctures. OPT
