battery and its water/acid content
Old Jan 19, 2012 | 11:49 AM
blackbronco's Avatar
Default battery and its water/acid content
I have a quad that I don't used very often. I bought it used and its needed a new battery since day one.
Yesterday I pulled the old battery off to take it to the store get a replacement. When I looked at the battery there was NO acid/water in it! This is NOT a sealed battery. Its an interstate. You can unscrew the little cell caps and see that its wet like there was fluid in there at one time.
My question is can I revive the battry some how? I have left over acid from other batteries that I filled and I have distilled water. Can I ad a little acid to each cell and fill it the rest of the way with the distilled water?
Old Jan 19, 2012 | 12:02 PM
There are chargers that can "revitalize" a dead battery up to a certain point,but if yours is bone dry the plates may have sulfated too much and shorted out? You can top off with distilled water ONLY no battery acid and drop it off and see if can be "desulfated" if you don't have this type of charger,but we never had too much luck on the ones that were brought in to us! Replacement might be a better choice since you don't know how old it is? Plus peace of mind out in the boonies is worth something with a fresh battery you can trust! Purchase a battery tender and batteries will last at least twice as long! I've got one almost 4 1/2 years old and fires right up! OPT
Old Jan 19, 2012 | 04:42 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
dry batteries are most likely junk after being that way as the acid plates will be no good. just buy a good new one and issues are solved.
Old Jan 22, 2012 | 07:30 AM
switzomatic's Avatar
I agree with them. Battery is most likely junk. If there's a Harbor Freight near you go there for a trickle charger. They are under $10 and if you watch for coupons they usually have them for $4.99. I have one for every machine and use them religously. My 05 800sp still had the factory battery in it when I sold it around 09 and still worked great.
bzdok1234
30
Feb 23, 2016 01:55 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Ronbo6270
Aug 6, 2015 11:54 PM
ScopeZ_
Jul 28, 2015 01:44 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
