500 H.O. low vs. high range
Old Mar 23, 2012 | 08:32 PM
beyondupnorth's Avatar
Originally Posted by TLC
Can,t see how a 500 Scrambler with the same motor,belt ,primary and secondary clutches and belt cover and belt cooling system of a Sportsman can ride slow trails or cruise at 60 mph with out a issue but the Sportsman cant.
I have changed the belts on 500 Scramblers and 500 Sportsmans and if there is a differance some where I sure can not see it.
Yes there gearing is different ,one has a high range only tranny and the other has a tranny with both low and high.
If your low range ever quits working on your Sportsman you basically have a Scrambler with racks. LOL
They will do it, the belt just won't last as long, and likely some cvt parts too. I know on mine I can feel where the clutch stops slipping on the belt right around the 7 mph and higher when I'm in high range.
Imo if you keep dipping below 7 mph in H your belt life must drop. Can't say I have I have proof as I try to avoid that senario, but it makes sense to me. Of couse the heavier the machine is loaded the more the wear will increase.
Old Mar 24, 2012 | 08:00 AM
Specta's Avatar
wind it out in low, my 2012 550 touring is turning 5000 rpm at 30 mph in high
Old Mar 24, 2012 | 11:31 AM
That's not bad. Hmmmmm..... may make me rethink an 850 for the next quad. If I can tool along at 30 in the snow in low I'd be happy.... hmmm....
Old Mar 24, 2012 | 12:57 PM
Specta's Avatar
Grim Reapers and my 2012 550 Touring EPS in the snow - YouTube
No question an 850 would have done better being able to turn the tires faster, no substitue for power in snow.
I'm fine with the 550. Doug wont let me take the 850 Touring because he thinks he should return at least one of these that is resalable.
ReconBayou
Oct 31, 2022 05:37 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
