I need some 12" rims
Old Mar 27, 2012 | 09:31 PM
Blake.'s Avatar
Default I need some 12" rims
maybe you can help me out.
dont care what brand. or even if they are just stock rims off a newer polaris. as long as they will fit my 96 sportsman 500. i'll even be ok with a set of 14's if the price is good. prefer 12's though...
i just need a set of wheels for my sportsman so i can get some larger tires since i'm having a hard time finding 27-28" tires for my 10" rear wheels.
honestly i'd be fine if i could find 2 steelies to put on the rear.
i dont really care about having pretty rims. just some that wont look like crap.
I'm located in South Georgia.
looking for some priced 150 or less, bc i can get a set of new steel wheels for 220.
thanks,
Blake
Old Mar 28, 2012 | 04:48 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you check your local craigslist or maybe ebay?
Old Mar 28, 2012 | 10:41 AM
Blake.'s Avatar
i live on craigslist. haha I've been looking on there a lot and all i find is the wrong size or people who have stock 12" rim's and stock tires but wont separate.
havent checked on ebay
Old Mar 28, 2012 | 05:04 PM
TLC's Avatar
TLC
I would not go bigger then 25" tires on a 96 Sportsman. The first SP500s 96 and 97 did not have CV joints only U-joints and heavy over size tires make cause some Snap Crackling and Pop.
ITP Mudlites come in 27-12-10 for your rims. but the less agressive "AT's" not the agressive "XL" or "XXL" lugs. Mudlite ATV Tires
More agressive Dirt Devil XT ATV Tires come in
27x12.00-10 Rear 6 Ply
GBC Dirt Devil XT ATV Tires
Old Mar 29, 2012 | 05:59 PM
Blake.'s Avatar
there's a lot more options for a 12 inch rim.
and if i do break an axle or u-joint, i'll just replace it with something stronger. no big deal.
Old Mar 29, 2012 | 11:16 PM
Tonyxp's Avatar
Blake, I believe that you can run a newer double cv in your current machine but have to get new outer hubs as well. Just a heads up if you find parts for cheap. If you run 27 or 28 inch tires you will probably have some tire rub. You may need a lift to clear the tires at least in the front. The back has more room.
Old Mar 30, 2012 | 11:29 AM
Blake.'s Avatar
I was planing on a 2 inch lift to clear em. And thanks for the heads up on the cv's. Ikk look further into it.
Old Mar 30, 2012 | 12:04 PM
iamflagman's Avatar
I'm not sure what bolt circle you need but I have 4 new never been mounted on anything, 12x8 inch 4-4 inch Bolt Circle that I will be selling very soon. Summit Racing SUM-159-12844M4 - Summit Racing® 159 ATV Series Machined Clear Coat Outback Wheels - Overview - SummitRacing.com
Also included is the 10mm lug nuts or 3/8 inch lug nuts. I bought the set for the new tires that came with the set, but the wheels do not fit my Suzuki Ozark.
$225.00 plus shipping.
I'm located in Central South Carolina
If you are interested send me a Private Message.
John Finn
Old Apr 2, 2012 | 10:00 PM
Blake.'s Avatar
i have found some for 165 shipped.
https://www.4atvtires.com/atvTires/s...407&cat_id=738
trying to see if i could find some cheaper.
Old Apr 3, 2012 | 10:19 AM
TLC's Avatar
TLC
Try for Aluminium alloy vs steel, your u-joints will love you for it.
