ADC question for OPT
Old Jun 16, 2012 | 06:17 PM
Mongrol's Avatar
"Official Site Skeptic"
Default ADC question for OPT
ADC started growling so I changed the fluid. Clear with no bubbles so I ran a resevoir full through per side. Still a bit of noise.
Question is, how much fluid does the system hold to get a total change?
Thx in advance.
Old Jun 16, 2012 | 07:03 PM
Gear case shows to be 9.3 ounces (fluid level with fill plug threads) Doesn't show capacity on the adc,but you remove the bleeder valve cap on the side of the gear case and attach a hose(to keep from making a mess) open the bleeder valve and pour in fresh fluid in the reservoir as the old fluid bleeds. Make sure the reservoir bowl doesn't get too low or empty (or you can have trapped air problems) Keep bleeding until the fluid is clean coming out of the hose,then tighten the bleeder valve,fill reservoir to full line. Forgot! I believe there are TWO bleeder valves and you alternate to each side side to bleed(as you close one side while still keeping the reservoir level above the minimum line) until the fluid drains out is clean and no air bubbles,then top off the reservoir to the max line. It's been a while! OPT
Old Jun 16, 2012 | 07:07 PM
NoJoke's Avatar
Howdy Mongrol......don't know the answer, but curious about "per side"......does the 550 have two separate resevoirs for ADC fluid?......NoJoke
Old Jun 16, 2012 | 07:17 PM
Just one reservoir,but two bleed valves on the 850xp,MAY be only one one on the 550,can't remember off top of my head OPT
Old Jun 16, 2012 | 07:22 PM
bobx2's Avatar
There should be two bleeder valves. One on each side. My '07 X2, my wifes '09 500 and my '11 all have two.
Old Jun 17, 2012 | 06:37 PM
Mongrol's Avatar
Ya, OPT is correct. 1 resevoir, 2 bleeds.
I've done it a couple of times before, but this time it seems to require a lot more fluid to go through. I;ll do it again.
Thx guys.
Old Jun 17, 2012 | 11:05 PM
Could be why some have had problems with the adc. The fluid has to be changed pretty often and if any air is left in it or the flushing old fluid isn't through enough,could cause problems. OPT
Old Jun 18, 2012 | 03:57 PM
NBsportsman's Avatar
If you still have chatter after you flush and bleed the ADC reservoir change the oil in the gear case. Since I started changing mine every 50hrs I haven't had problems....
Old Jun 18, 2012 | 10:19 PM
Mongrol's Avatar
Changed front drive fluid about 8 riding hrs before doing the ADC fluid and still does it.
Appreciate the input tho.
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
