2005 Sportsman 700 EFI - Ignition Issues
Old Jul 25, 2012 | 11:05 AM
stanollieyeti's Avatar
Default 2005 Sportsman 700 EFI - Ignition Issues
I have a 2005 Sportsman 700 EFI that I bought new. Recently this past spring, when I would turn the ignition to start it, I would hear a click, but the engine would not start. If I turn the key back to the off position and then try to start it again, it would ususally fire right up.
Over time it has gotten progressively worse. Instead of just getting the click once and then starting, about a month ago, I noticed it might take two or three attempts, getting a click each time. And then on the 4th or 5th time it would start.
This past weekend, when I turned the key, there was nothing, not even a click. After a few attempts, I would get a click when I tried to start it and after a few more attempts it would start.
So I'm posting this today in hopes that someone might have had a similar problem and solution. From looking at some diagrams, replaceable parts would be:
1) Ignition switch
2) Starter Solenoid Switch
3) Starter Unit
4) Battery
Before I go and buy any or all of these, where should I start?
Thanks in advance
Old Jul 25, 2012 | 11:42 AM
Welcome to the forum! I'd first have the battery load tested especially if it's an older battery.Plus make sure while running you are charging 14 volts back to the battery. If the battery and charging checks out then it could be a solenoid beginning to short out. This would be my first guess,but ignition switches can do the same thing. Just eliminate one thing at a time. You can always jump across the solenoid contacts to eliminate the starter as a problem. OPT
Old Jul 18, 2018 | 08:35 AM
It turned out to be one of the ignition wires in the steering column.
ripperray
Oct 10, 2023 02:42 AM
neilbedwell
Nov 10, 2018 11:02 AM
Land_shark1
Jul 10, 2015 12:53 AM
jag6510
Jun 15, 2015 05:59 PM
May 27, 2015 11:15 AM
