new to forum, need help
Old Aug 19, 2012 | 01:06 PM
xyz321's Avatar
Default new to forum, need help
Hello all,
new to the forum, I joined because I bought my first atv this year, an 07 sportsman 500 efi browning edition, the problem, there is a delayed reaction when i turn the key on, kill switch is on as well, so,... delayed cluster lighting up and the ominous clicking sound underneath, machine has always started, however the delay is getting longer and sometimes I have to turn the key off again to get it started, thru tireless hrs of research it sounds like the pdm or ecm, my question,
is there a new part# for the pdm? someone mentioned an upgrade, my part# is 4011517, can i order this or should i look for an updated #
any help would be appreciated
Old Aug 19, 2012 | 05:52 PM
Welcome to the Forum! Part # still shows to be the same. Please don't double post in the expert and normal thread area,causes some confusion. Cycle Parts Warehouse still shows same part # 4011517 for about $360. They usually show any updated items if available. OPT
Old Aug 19, 2012 | 07:42 PM
xyz321's Avatar
Thanks OPT, appreciate it, sorry for the double post, have never posted on a forum until now, will not let it happen again. I think I will run the machine a little longer to see what happens, (unless it will do more harm) I just dont want a dead machine in plow season, outside of this issue, the polaris is everything I need it to be,
Thanks again
Old Aug 19, 2012 | 08:01 PM
Just make sure the battery is receiving 14 volts while running. This is one of the functions of the pdm along with operating the cooling fan. OPT
Old Aug 22, 2012 | 10:02 PM
xyz321's Avatar
Well I went out a couple of days ago and got 14.5 volts at the battery while running, its sat for a few days, tonight, almost couldnt get it started, read badazz 400 thread, sounds like I will be purchasing a new pdm soon,
Old Aug 23, 2012 | 07:23 AM
Have the battery load tested first!! It could be just a dead cell and not holding the charge back to it from the pdm! Especially since you said it's getting 14.5 volts back to the battery while running. OPT
Old Sep 12, 2012 | 10:07 PM
xyz321's Avatar
Default new pdm
Hello OPT,
well battery load tested just fine, I broke down and bought the new pdm, found it for $322 at babbitts, hooked it up and machine lit up and started like it is a new machine, now, when I go to run my winch, all is hear is a solenoid clicking under the steering column, it worked fine before, any help, at least the machine is running
Thanks for the guidance
Old Sep 13, 2012 | 08:05 AM
Tap the winch while you push the switch and see if it works. Check that all connections on the on the winch commutator connections tucked up under the right front fender are tight and also at the winch itself. If all connections are good,possibly the commutator needs replacing or the winch motor itself may need to be cleaned up and serviced. Plus you can use a meter or test light to see if the winch is getting power when you push the switch. OPT
Joe454
Nov 20, 2020 01:19 PM
Alex G.
Sep 11, 2017 11:38 PM
Whitelx1
Oct 2, 2015 10:55 PM
fredrikrosen
Sep 28, 2015 09:58 PM
kbazzy
Sep 26, 2015 11:26 AM
