Code 26
Old Sep 3, 2012 | 07:17 PM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
Default Code 26
Have a '09 Sportsman 800 Touring and check engine light just went on. Ran the diagnostics, and came up with a code 26-Vechicle Speed Sensor-Implausible. Well, I can understand most of that, but being close to SSI, "implausible" was a word I don't have in my vocabulary. From what I come up with is that there is no troubleshooting, replace it. My problem is, I question whether the sensor is bad. The ATV seems to be off on the idling circuit. Does anyone know if this sensor circuit can be troubleshot or should I get into the TPS circuitry?
Old Sep 3, 2012 | 07:32 PM
NoJoke's Avatar
Howdy uncertifiedmechanic.......this link may shed some light on the code 26 thingy.......good luck, NoJoke
Polaris Bulletin: blink code 26 - Polaris RZR Forum - RZR Forums.net
Old Sep 3, 2012 | 07:39 PM
If the speed sensor is bad no speed or mileage accumulation will work. If speedo acts ok,then I would just disconnect battery for about 30 seconds and see if it removes the code. If idle is erratic then it could be the old problem of map sensor wiring shorts. Look at the "sticky" in the expert section about this problem. OPT
Old Sep 30, 2012 | 01:56 PM
Default code 26
Thanks OPT for the advise. Found a bare wire on TPS harness, used liquid electrical tape to seal. Ran codes again, after running the ATV around for a bit, this time coded out as a 22
Old Sep 30, 2012 | 03:25 PM
Just unhook the battery for thirty seconds and see if the codes clear. OPT
Old Sep 30, 2012 | 07:14 PM
Sorry OPT for the confusion, I ran the ATV around prior to repair. The ATV coded out a 22, that's when I went to the TPS wiring and found the Green wire to have a bare spot. Decided against Polaris repair kit, went for liquid electrical tape. All is good now, power is back, fuel economy, no hesitation
Old Sep 30, 2012 | 07:29 PM
If you do need a tps harness kit in the future check the "sticky" at the top of the expert section on stronger efi harness kits.DON'T blame you on the Polaris kit,same thin wiring that you already have! Good luck on the liquid tape. OPT
Old Oct 2, 2012 | 08:16 PM
liquid tape is a success OPT. Can't believe Polaris uses thin wire on such a critical wire harness. Wrapped up the harness with weatherproof foam backed tape, that should eliminate any contact to metal. Thanks again OPT for the help
Sw00p
Sep 24, 2015 02:50 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
