Blown fuse/s?
Old Sep 26, 2012 | 02:16 PM
cwright's Avatar
Finally got a replacement ECM and installed it. What do you know... all my lights, gauges, etc. work after all! It's turning over now as it should with my key, but it's not getting fuel to the carb, so I'm going to start trying to figure out what's going on with that. Thanks!
Old Sep 26, 2012 | 04:02 PM
Glad you finally got the ecm problem out of the way! Hopefully you just need to clean the carb and jets and be on the trails. OPT
Old Sep 27, 2012 | 08:26 PM
cwright's Avatar
If I have fuel running freely from both lines and it won't come out of the outlet line to go into the carb from the pump... then is my pump bad? Can you rebuild these or even clean them of would I be better off just getting a new one?
Old Sep 28, 2012 | 04:06 AM
You can clean the diaphragms and inlets of the pump.Could be just trash/varnish build up. Repair kits are available if diaphragms need replacement. OPT
bmxatv10
Oct 14, 2022 06:23 PM
fd24
Jan 16, 2019 08:59 AM
kodiacrunner
Oct 4, 2015 11:52 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
jsmit116
Sep 18, 2015 10:34 PM
