oil change interval
Old Oct 12, 2012 | 09:55 AM
MYWAYOUT's Avatar
It really depends on how it is ridden and temperatures....
Personally I change mine at least every 60 hours or once a year.
But will normally change it twice a year... I run Mobil 1 synthetic oil and use K&N oil filters..
Personal preference..
Old Oct 13, 2012 | 04:23 AM
toyoman28's Avatar
I went ahead and changed the engine and trans oil ...glad i did. It seems the oil looks much cleaner on the dipstick than coming out the drain and it smelled of stale fuel as well. Yearly changes at least for me now.
Old Oct 13, 2012 | 09:22 AM
TLC's Avatar
TLC
If you want a oil filter for a 425,455 or 500 Polaris these will work.
STP: SM017
Napa: 1358
Fram: CPH6607 and PH6017A
K&N: KN-303
WalMart SuperTech: ST7317
AC Delco: PF2135
Wix: 51358
Old Oct 13, 2012 | 03:17 PM
Raven95150's Avatar
Here's a nice cross reference chart. It's a few years old, so it's missing some models but from what I can tell, pretty much all Polaris ATVs use the filters in section 5. Use the longer ones if you have room as they have more filtering media. Also, it appears that Walmart (at least in my area) no longer carries the Super Tech filters and has replaced them with Purolator. Whatever you do, DO NOT USE FRAM FILTERS!
http://motorcycleinfo.calsci.com/FilterXRef.html
Old Oct 13, 2012 | 06:32 PM
  #15
Spdecat's Avatar
Originally Posted by toyoman28
Maybe a stupid question but how often do you guys change your oil if using a good synthetic like amsoil? The manual for my 2008 Sportsman 500 HO says every 100 hrs, 620 miles, or 6 months whichever comes first. Well, the 6 months is nonsense but how often does everyone else do it if you don't hit the recommended mileage or hours in a year? My amsoil still looks new after 2 years and 600 miles.
I had the same machine as you 08 500 but mine was carb . I also used Amsoil and changed the oil every 1000 miles or about 3 to 4 times a year . I also changed the front and rear fluids at the same time . Buy Amsoil by the case and your save some money
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Alex G.
Sep 11, 2017 11:38 PM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
